Long story short. Had to do some light plumbing yesterday that turned into heavy plumbing when I found that "Someone" used plumbers putty on threaded joint when they should not have.
As a result I had to break out the Dremel 4000 and metal cutting disk. I was making pretty good time with it using the Flex Shaft because it was easier to handel. I know I was asking a lot for the Dremel to cut the Drain Basket but it was the only thing I had.
Well the Dremel started to smoke, I mean bad, black, stinky smoke. Came out of the cooling vents. I stopped using it, I was able to cut enough to work in a screw driver to pry the basket out but I was scared to use the Dremel any more. I hooked it back up in the shop after it had cooled down and I powered it on. No smoke, sounded fine but I didn't try to put a load on it.
So, what's the deal? Is this normal, was I asking too much of the little guy? Will it be OK to use on wood and light cutting jobs I have been using it for or should I chunk it?
