Very , very cool , I have been following this but I can't remember if you covered how you made the black garbage bags , ........... soooooo , how'd ya do them ?
Thanks. I made the trash bags using this method:
1. I cut a small piece of GLAD food rap plastic and cut it into the size I wanted; more like a square shape napkin.
2. Then I took some sugar( sand works fine too) and placed some in the center of the plastic.
3. I gently folded all four corners together then used a piece of thread to tie the plastic together.
4. Then I took a spray primer and sprayed the entire plastic. You might want to use a plastic type spray that is compatible with such materials. I did not have any on hand. So I just used a car primer spray can.
4. After it dried for an half hour to an hour, I took a black spray can( Tamiya Matt Black, but any will do, I guess) and spray the bags until I covered all areas except the bottom. This area will not be seen anyway. That's it. Instant trash bags.
I am a cheapo modeler. So O try and look for all cheap methods to building. That is why I decided to do this project. A special note. I have not been able to find a compatable spray that will stick to plastic wrap. There probably isn't but remember, it will flake so handle the bags with care or the paint with flake and fall off. Make sure you glue them in place after the paint has dried. It would be even better if you can find a plastic wrap already colored in black, if there are any please let me know.
