Tankbuilder
Ahoy there.
Introduction.
As I'm working on my 1/32 scale Lindberg PT boat rebuild I am also working on another 1/32 scale Lindberg PT boat model that will also be radio-controlled.
I think this kit is out of production - again.
I'll share with you some of the many modifications I'm doing on this model. However, I am *NOT* intending o do all the major modifications that are needed to make this a really good looking facsimile of an 80' Elco boat.
Here are a few of the problems with this kit.
#1. The hull is 3/4" too short to be 80' in real life. That in turn throws everything else, especially the foredeck layout, off.
#2. The hull is the wrong shape for an 80' Elco boat especially at the bow. The shape is better suited for the earlier 77' Elco boats.
#3a. The chartroom, bridge and dayroom are overly simplified and the chartroom does not have the transverse roof curve it should have. #3b. The large engine room vent is the wrong type for a PT-103 Class boat. This kit is supposed to represent John F. Kennedy's PT-109 and it should have four tall vents.
#4. The hull and thus the deck does not have any camber. The middle of the deck should be slightly higher than the edges when viewed from the bow or stern.
#5. For some strange reason the two .50 caliber gun tubs are not the same diameter. I was lucky in that this is my second kit and I was able to swap out a gun tub from my earlier built boat. Thus one boat has two of the larger gun tubs and the other has two of the smaller ones but at least each boat has two gun tubs the same diameter.
#6. The guns. Super simplified renditions that are very toy like.
#7. There are two very large round hatches on the rear deck. These were for access to he rudders. They were not present on any real boat.
#8. There are two fairly large recesses on the removable center deck. They are for the turn-buttons that hold that deck in place. I filled those in too.
#9. The splinter shields at the bridge/cockpit area are mostly wrong.
#10. The foredeck hatch closest to the chartroom is in the wrong place and needs to be moved to the right.
I could go on and on but you get the idea.
One thing I should mention is that the good people at Lindberg sent me the parts required to build a PT-103 Class boat when I emailed them and asked about buying them. They sent the parts gratis.
So, let's start by improving the looks of the main deck.
Here's an image of the kit deck showing all the wrongly positioned foredeck hatch.
Here's an images showing the rear deck modifications to fill in the surplus openings.
Here are two images showing the modifications I made in order to move the foredeck hatch to its proper location and to also move the removable center deck aft 3/4". Ideally I should add 3/4" to lengthen the rear of the hull but I'm not going to do that as it would mean a lot of work adding the 3/4" to the deck and scribing the planking.
A quick note about the planking. You can omit scribing planking since on many boats it wasn't visible. I added the planking simply for aesthetics.
Here are three images showing the modified main deck and the scribed on planking.
More to come soon. Thank you for looking. I welcome comments.
Cheers from Peter
Introduction.
Cheers from Peter
