Thank you James, I can tell the elves have been working, all my cookies are gone
Thanks MP!!
Thank you Erik!
Thank you Mike
As always, Thanks Terry!!!
Hi Rick, Thank you!
Hi Stug, Appreciate the kind words!
Thanks Jeff
Kevin, Thank you!
Hi Martin, I still going, just kinda slow
:bgri
Thank You Bob, I'm having a blast building this thing up!1
Thank you Andy!!
Thanks Chris, Sorry about the coffee
Left off last time showing a mock up the firewall, here is a mockup of the floor of the cab also. Using K&S sheet goods of tin and copper. These solder well and are soft and easy to work with...
Building up the firewall first....
Checking the fit....
Heater hoses....
On to the floor, I use a piece of Homosote to work on when I need to pin together parts for soldering. It is a paper building board product that you used to find in the home centers. It is dense and holds pins well. Serves the same purpose as Chuk's ceiling tile.
A sloppy solderer's best friend...
Filing the front square....
Mock up time...
Added some rivets and opened up for the shifters, have a two speed rear axle so I need the second lever. The shifter opening has Scale Hardware rivets while the others are a photo etch strip...
The shifters are just set in place for now until the seat is in..
Thanks for looking in!!
Randy
