paddy
Looking forward trading it thanks BobI think it's this book he talks about the wonders of flying back then, making practice landings on clouds. Wonderful passages.
Turns out the jaws on the one I bought are stainless as well. The base is a very solid aluminum CNC machined and hard anodized with a steel lead screw. At $45 it was well worth it. Very weighty (not light) and very solid once I tightened up all the screws. The tolerances were so tight that it was hard to move the jaw, so I added a .02mm shim which wasn't enough. Added a second which made it a .04mm (.002 inch) shim and the jaw moves nice and smooth with just barely a hint of play, which is perfect. There were several other iterations of the same vice for up to $55 which is still a great deal compared to the Innocraftsman vice.That is actually identical to mine Paul including the hard case, i just took the picture of another of the faces.
The vice is interesting, i did look at one from innocratsman but as you say they were rather expensive although this one is stainless
The little vice with the stand is what it is. It looks to be made well. The fractal vice looks identical to what I just got with the exception of the name screened on the side. Just look around for what you would like. Like I posted, my fractal vice needed the screws tightened up and then I added some super thin shim material into the sliding jaw as It was just too tight to slide with the coating added. My guess is that it was just slip free without the coatings and the coating made it tighter. The small vice looks like a tool to hold small figures and parts for painting.@Heavens Eagle, you posted those while I had these in my 'Saved for Later' section. I don't see the differences, other than cheaper prices, but your opinion would help me decide, Paul.
I'll be asking about the shims when I get it. Next rewards from Prime in two weeks.Like I posted, my fractal vice needed the screws tightened up and then I added some super thin shim material into the sliding jaw as It was just too tight to slide with the coating added.
