Sherman in 1/16 scale.
The mirrors come off. This photo shows one on. However I asked myself the same thing. I'm betting the car modellers have a solution for replicating rear view mirrors.
The Sherman models I've seen have them folded in with the mirror flat against the hull to avoid having to deal with that.
Ahem...
78.7 x 12 x 0.02 inches -
Flexible Mirror $10 for LOTS of projects​
Got the Aber barrel on the 30 cal.
Working out where the stowage will go.
Instead of doing paint on that brass barrel, use some blackening treatment on it. After soaking for a little while it builds up a flat black coating on the brass. I take it out rinse it off and then gently rub it with a paper towel. That removes the flat black and burnishes the brass to a color that looks more like worn gun bluing or browning with highlights. No paint needed and looks so much better.
If you can't find USCHI, the Jax 3.5oz Selenium Dioxide based blackening agent for brass is $10. Also, Ammo of MiG does make a PE Burnishing solution. NOTE: There is a separate solution for blackening white metal (or pewter) tracks from all the companies.
For blackening the brass I thought about trying my ol' school liver of sulfer.
test it on some spare PE frets before chancing it on turned brass barrels. I've seen it used for silver, copper, and bronze but not brass. Each agent has different properties and that is why I specified to be careful to order the agent for brass and not the one for pewter (white metal as in tracks) if deciding products from Ammo of MiG or USCHI. It will be cool to know the results!
I showed what the USCHI does. It works quite well and gives a fairly realistic looking color.
As Saúl stated, if you are using an unknown, test it on something first. Brass being an alloy with usually copper and zinc where bronze is copper and tin. Both bronze and brass may include small amounts of a range of other elements, including arsenic, lead, phosphorus, aluminum, manganese, and silicon. Brass can also have small amounts of tin.
Best to be sure before detonating an expensive brass barrel.
@Heavens Eagle and @Tim A., I still have a rather large bottle of Blacken-It as I bought a case from Gateway Hobbies in NYC over 25 years ago! Last bottle of six. I had bought a slew of FriulModellismo's (original name) tracks and was disappointed by the clam type connections. Later, the name was shortened, owner moved form Italy to Hungary, and the connection became drilled out holes with wires. Anyone remember this?
:oldguy:
Note the spelling and country of origin:
I am good with the small bottle that I have. The plus part of that is that I "know" it works.
Thanks for the offer Saúl. Maybe Tim could use it?
Went ahead and ordered the Aber 50 cal barrel upgrade as well.
I may have to get a job...I swear the next build is going to be STRAIGHT OUT OF THE BOX.
I got the AFV 50 cal and had a bent barrel twice - the replacement was bent also. I Posted this on the AFV forum on FB and complained that the 100% failure rate was disappointing for an $80 AUD gun. I would have been able to make a better decision if told 'up front' that the barrel will be bent. I was asking if the MG42 barrel would be bent and was told (by David Parker)that i wouldn't have to worry because they would not be selling me one.
I replied that I was justified to expect a warning notice before purchasing and that if you bought an armout kit or plane kit with a bent chassis/fuselage, you would go out of business at a 100% failure rate to meet expectations. I was attacked by all (for questioning a celebrity modeller) and the 'fan boys' told me to just heat the barrel as a fix but my point was at $80.00 for a a simple gun, I should not have to do anything. If it is an excepted issue, then why isn't the issue advertised or just sold with a BRASS Barrel - I ended up buying an Aber barrel (an extra $20.00 and haven't bought anything from them since (after dropping about $1500 with them prior to that).
This meme sums it up when you wake up to a dozen comments on something you posted the night before...
I got beat up on an antique tractor forum for how dangerous and irresponsible it was for telling a guy to put his tractor in gear to keep it from rolling away I don't know what those people thought we did all those years with stick shift vehicles?
Thanks for the heads up. Untill the last few years I couldn't afford aftermarket offerings so, I'm just unfamiliar with the good, bad and ugly. It's a learning curve. Think I've figured out the right combinations for what I'm trying to do with the guns on this build. May not be perfect or "right", but if they look the part I'm happy. Treating these builds more like paintings I guess is what I'm doing?
I guess I would have taken a beating for telling folks I had to drive a f250 with no clutch for about a year. Starting in granny gear at a redlight with no clutch was a great learning experience.
Ah the good ol' days.
If you had a hit or miss starter and knew it, parking on a hill was standard procedure.
Been there, done that. The clutch cable would often break on my Kawasaki 900 on the way home. No, I don't have it anymore. I sold it in the mid eighty's. Gary S.
