Every now and then you come across a model that beats you. It either doesn’t fit, its detail wise all wrong or you heart was never in it and life is too short. If the manufacturer can’t be bothered to get it right , why should I ? You know the sort of thing.
Well for me it will always be the Revell 1/8 E-type. It beat me into submission. Partly because of the parts quality and partly because of my inability to get two panels the same shade of colour.
The one I never mention because it was so bad was Tamiyas 1st ever big scale car from 1968. It was a 1/12 Honda F1 RA273. I bought it several years ago, I think it was released in 2015, but mine was earlier with out the now included PE fret. I remember looking at the soft detail and under engineering meaning many parts were moulded into one block and thinking…….not for me. I think I actually threw it away I certainly never started it. This was from a time when like a lot of Japanese products, we were all sceptical. the car industry was seeing Datsun's and Toyotas replacing the home built models, Honda and Kawasaki were taking over the bike market and even stalwarts like Airfix/Revell and Frog were under attack from Tamiya.
Remember when they launched this model the car was current and state of the art :)
Anyway fast forward 11 years and I think I might have learned enough now to tackle this model particularly as there is now an endless amount of detail pics on line of the real thing. The only thing holding me back is all the other gallant attempts on line by some excellent model builder have not managed to make it look like the real thing…they all look like a plastic toy, I can’t put my finger on it now but once I can see why I will give this model another go. ( oh and i got it really cheap) :cool:
Cool that you got it cheap. I remember most of the 1/12th scale cars were always too expensive back in the day. I had several R/C cars back in the day. The Tamiya Baha Beetle, the Sand Scorcher and a slant nose 911. Not sure where they went off to. Divorce and moving around with having my Storage building partially demolished and broken into are probably part of the issue. If I could go back in time I would pass on any R/C stuff. Just not worth it with 20/20 hind sight. In a box I have the parts from a Tamiya Ferrari formula one that had all kinds of fit issues especially around the engine and rear body areas. Was not all that impressed with it so...
Also had a 1/8th scale Martini racing Porsche that never was finished and also seems to have disappeared. Oh well, probably not worth the trouble of digging through stuff to see if they are around.
Amazon delivered but these are NOT Prime Day specials.
I was searching for replacement 1/8th inch (3.2mm) four jaw brass collets for my pin vises and found them in sets of ten but ALL the same size! Luckily this showed up in my feed. Duliwo 21 piece set: one pin vise, ten assorted four jaw brass collets, and ten carbide drill bits for only $10! I read reviews, watched videos, and I must say I am VERY pleasantly pleased with the quality of the pin vise!
Idiot me opened the collet blister package and spilled the contents. The collets themselves are not labeled.
This DSPIAE AT-ED02 (02 refers to it being gray instead of red) had a $5 coupon and I have seen several YouTube modelers using carbide PCB bits with this so, I am in!
Don't throw out the outer box as those are the only instructions included. The body of the drill did have a paper sleeve with a key to the buttons. Also included in the packaging, but no storage for it in the box, is a rather short USB-C to USB2 cable. Almost useless until you realize that the USB-C plug is a tad longer than most. Luckily, the fancy cables I bought everyone here for their phones works well and the drill body does light up to let you know it is charging. Also, you can still work with it while charging (if your cable is long enough).
Two nifty storage pods are included and can hold 20 drill bits. Obviously, the holes for the shanks are identical in size but too close together ot fit collared carbide bits. Then I learned that DSPIAE sells TWO types of tungsten steel bits. The one that comes with their hand drill (being tungsten, less brittle that carbide) and one called flat shank with a protruding tab that locks into a slot in the electric drill to prevent slipping. Only 18 sizes though.
Last, I read the instructions and it advises against using collared drill bits. I took one anyway and... it didn't fit! The shank on the bit is too fat! Luckily, I removed the DSPIAE collet and used the brass one and no issues. The one from the DSPIAE doesn't fit the DULIWO pin vise as it is too thick in diameter. I can still use my new hand vise with the other collet sizes in the set. Overall, I'm pretty happy with my purchases.
Here's the 6-foot 90-degree angle cable four-pack for $10 I bought for my household's phones (with one extra) and the plug is long enough to charge the DSPIAE Orbit drill:
All i would say is since buying my electric pin vice i have never used my manual ones. its much easier to get an accurate hole if you are not having to twiddle the holder as well as the bit, more likely to be to size and less likely to snap the bit on sub 1mm sizes. with models like the MFH white metal subjects its quite likely you would need to drill up to 500 holes from 0.5mm-1mm,. using a cutting fluid is essential on white metal but they are a dream to use on plastic and resin.
For Pride Month, I thought I would treat myself. After all, I bought a complete set of nail files at Sally's Beauty Supplies and those nifty glass files and buffers, right?
So, as I am using a 320 grit sanding wheel to shape my toenails, I almost gagged on the keratin dust flying everywhere that I decided there must be a better way!
Arriving tomorrow since it was 30% off (from $90 to $60USD):
I will let you know how it works. Seems to be really good as they include two wee-wee pads (for the excitement?), ten tissues (for the emotional happy tears) and a tickler brush along with a power supply to recharge the battery but it also works plugged in.
BrandSYDRON
MaterialABS, Aerospace Aluminum, Magnetic Metal Cover Plate
ColorSilver
Item Weight2.7 pounds
Item dimensions L x W x H8.15 x 8.15 x 2.2 inches
About this item​
  • 1000 Pa Tornado Suction: High-tech silver-finish silver housing for a clean, professional look—no extra bling needed. Underneath, a brushless motor spins 360° cyclonic airflow, trapping 99% of stubborn acrylic and gel dust. Whisper-quiet gentle modes maintain peace; max suction eradicates salon debris so you can focus on artistry.
  • All-Day Cordless Freedom & Unlimited Plug-In Power: 7800 mAh battery fuels up to 8 hours of coffee-shop nail art or client pop-ups. When inspiration strikes a marathon session, plug in-and-play keeps your flow unbroken.
  • Zero-Maintenance Filter Ritual w/ Artist’s Kit: Swap soiled pads in 3 seconds—no cleaning, just pure focus on your masterpiece. Now comes with 10 silk-finish filter papers, 1 magnetic reusable filters,
@Sharkmouth
Nice chat Saúl! Interesting little acquisitions there. I got notification that my CNC machine is in the shipping pipeline. Coming over by ship so it will be a bit yet. The base machine is supposedly 75 lbs and then there are all the accessories I also ordered. Probably should get my place set up and cleaned up to have a working place for it.
Have some other big items coming in the next couple of days so will post once they get here.
Got a few things today and am quite happy. The big one is the Trumpeter 1/35 KA 52 Alligator. Its bigger than I thought and looks to be quite the build.
I also decided to try this monster.
And finally I got some airfield equipment and signals stuff by Leungs Workshop.
Now at some point must do and airfield diorama and a signals dio.
Regarding what, the drills and bits? Negative, not reading anything that encourages me to spend money right now. Getting new roof without the aid of insurance. Long story...
:lol: I guess you didn't read it as I was trying to behumorous about files and sanding!
Don't mention new roof to me! Fingers, legs, and eyes crossed!
Testing two things, uploading videos and the end caps of the drills for manual mode.
The Duliwo seems to use bearings as it is very smooth and continues to spin like a fidget.
The DSPIAE can be used in manual mode which locks the chuck but the end cap doesn't spin smoothly. I already misplaced the rubber cover for the USB recharging port. A light near the end cap lights up when in use.
My DSPIAE pin vice has a bearing under the end cap that fits to your palm. I discovered it when I accidentally pulled the end cap off. It isn't on tight, just snug. It doesn't spin as free as your little one Saúl, but it does work nice and smooth.
As to my Dremel, I can't make it as slow as the little one in your video, but I can slow it with the external speed control to where it is turning really slow. Over the years I have bought numerous chuck sets for my Dremel and have quite a number. I have found certain ones that spin true and use them a lot with a finger tightening chuck for it. It works. I am used to it and comfortable with it so I don't bother with the fancy new tiny drills.
Thing is, you look at it's mass as an issue. With all the time and practice I have with it, that mass makes it stable, especially with the external speed control. I never run it full tilt boogie. I don't think I even run it at 50%. Usually I run it at about 20 to 30% and have drilled hundreds of holes with a #87 carbide drill through plastic parts by hand and didn't break the drill bit. All in what you are used to.
Years ago I had a small (cheap, which is all I could afford at the time) battery operated drill and it sucked. Have gotten to the point where I just don't like battery operated tools.
@Heavens Eagle, I also use an external speed control for my Dremel and Foredom of which both have flex shafts fitted. One at each workbench (Garage and Laundry Room). The flex shaft concerns me as any twitch causes the brittle carbide bits to snap. My intent was to start holes manually and then turn on the motor. 200rpm is listed for the DSPIAE.
Foredom's rheostat controller... Yes, homemade about 30 years ago!
My Dremel speed control bought used in 2023:
The Dremel speed control has a lot more in it than a light, switch, and potentiometer. There is a small circuit board inside which makes the Dremel work really nice.
Flex shafts are great for heavy duty stuff, but as you found out the hard way, they can twitch and cause all kinds of issues. That is the main reason I don't have one.
I finally got the pre-paid order from Squadron. They finally got the item in stock (it was a new release). I did the order back on April 1. (No, don't go there) (Yet :wow: )
Anyway it showed up yesterday, super fast, 1 day shipping from Squadron!
And
I have to say I am impressed. Trumpeter seems to have upped their game, at least on the newer large armor. This has become a new scale that seems to be growing. Some is good, some is so-so as I have found out, and I am sure some is probably crap but have not seen any yet.
They used a lot of parts from the Hornise kit they released a while back. I was interested in this one with the big gun.
And yeah it is a bit bigger than what I already have.
@Sharkmouth
But then a while back Saúl sent me a number of decals including King Tiger Instruments and bezels with some other detail stuff for King Tiger interior. (are you seeing where this is going yet)
Yeah, I bought one. I can blame Saúl even though he wasn't twisting my arm. I did the research on the kit and what it has. The research, I think didn't do it justice. With over 1850 parts and looking at the detail in it, while not sure how correct it is, it is completely impressive.
The Nashorn is supposed to have over 1900 parts, so these are going to be projects to be sure.
Thanks Saúl! I think I will really enjoy this kit.
And then this was just something that caught my eye.
Hey, join the club! @jknaus can blame me for a few purchases as well!
Paul, if you're not done shopping (and want to correct the King Tiger's few soft spots, or the new Nashorn, which has a lot in common with the Hummel, don't forget that AFV Modeller has everything including detailed King Tiger build books broken down into two downloadable ebooks; parts one and two.
