All Righty ... What's on the bench today?
More work on the turret...gotta start planning on the base next I think. Got an order into the Scenic Factory. Also working on a shelf queen in the Model Cellar French Tanker and started the 1/16 Das Werk StuG III that I've been wanting to start.View attachment 182720View attachment 182721
Excelllent colors - its really hitting the mark on colors. :tens: Don't forget to add shadows at the end so it 'pops' properly with those light shades. :)
Ian- are you talking about the turret or the figure? Sorry...just clarifying.
Tojo- yeah I hear you. I'm using the AMMO Dark Yellow primer as a base coat on the StuG...but there is a lot there.
Thanks Ian...yes still loads to add. Was waiting to get the base sketched out a bit...tomorrow I plan on getting the groundwork done in earnest and then once the tank is placed I'll get back to weathering the tank and turret.
Took a break from armor today to build some Gundam with my boy. He also got me started watching Attack on Titan....mines the blue one...I like his gold one better.
I have been trying to make some vintage type mudguards or Fenders ? for some time now on and off but i just cant get to do what i want in a form i can reproduce for 4 corners. This looks ok for one but 4 the same will be a mission
I cant do compound curves and so its always going to be a compromise. fortunately even manufacturers in the 1920's tended to avoid them as well :)
What's your heat source? I got nothing for you on making 4 identical. I suppose you'd have to make a former or a mold of some sort.
I haven't used heat Bob, that might be more of a complication given my limited knowledge than an advantage , you are right though i need a jig which might take more effort than the mudguard itself :)
So here we are a day later and i have 2 front and 2 slightly larger rear mudguards.
i dont know if i can use these but its been a valuable learning experience :)
I could probably remove the brass bits now the sides are on as they should hold the shape but the brass does at rigidity and might be a good mounting point later
As usual i have no plan so i dont know how they will mount or what they will look like but who cares at this stage 🤣
I built a firewall for the old Wildcat years ago. Started with a disk and added a rim with sprue then back filled the inside edge.
Wow I have those photos uploaded here.
I tried to make it in brass but figured out I can do styrene easier. You can cruise through my photos to see what I did, wasn't very good but you get the point. Get your basic shape then fill in the corners and remove the excesses. In this case, you fill in the inside corners and round down the outside.
full
My whole hobby "shop" has been in such a mess that it reached the point where I just HAD to clean it up and organize everything again. I am about 2/3 done and then I will get the "prizes" built up. Have decided to do up a couple of sets. Multi platter for the CA application, and a regular large one, each with some other goodies. I have to get out into my garage tomorrow, move the Corolla out, move the old bug out of the way, and cut some wood. Had to get my work area cleaned up and organized first as it was totally out of control and I couldn't find stuff.
Mine has been in the same condition. Once I got the tool organizers built and installed on my desk, things were too chaotic and I spent a couple weeks just organizing and sorting out all my miscellaneous parts into storage boxes!
On my bench but still in its box is a An Airfix DE Haviland Chipmunk , gifted to me by a guy i know. not really my thing but its 1/48 and tiny, smaller than a lot of 1/72 aircraft. So what is the score with micro month models ?
Not on the bench but under it :)
I bought 2 of these self assembly stacks of draws, one for each end of my bench which will enable to compress a lot of parts currently in plastic storage boxes into an easier access set up. surprisingly good fit which was a bit of luck. Made in China of course but then everything is these days. I am quite sure if i had bought British they would have been twice the price.
I am taking a short break from building as i tend to work in a complete mess so i need to do something about that. I want to have a go at another MFH model car but the ones i have are way way more complicated than the car i have done and i think bench space needs to be plentiful so parts can be laid out. One difference that you find with MFH is all the parts are separate in bags so there are no sprues/trees to keep things in order and of course separate parts are not numbered so you can imagine keeping things in order is important as finding the small part you want, then putting it back in a bag of other parts can mean another 15 minutes to find it again :) .
