Rhino
Super Moderator
Using RAF interior green as a primer, I sprayed Tamiya LP-48 Sparkling Silver lacquer on the insides of the jet intake and splitter.
Guys! This stuff is amazing for NMF finishes. With the fuselage halves closed up, you cain't see much of it, but it's P-P-P-Purty!
Finished seat with initial IP. (Yes, you're quite right. The belts don't go through a hole in the seat on the real E28/39. "A hint of cockpit", remember?)
Ship Guys are always thinking about actual size in scale, so I usually use my ProModeler decal belts. The P/E belts are 4 inches in scale thickness, but they look cool and I paid for the sumbitches, soooo......
The first go on the translucent instrument detail backing and P/E panel was a touch out of register. No Problem! A dip in Windex and gentle cleaning removes the Future adhesive, and "Do-Over". Better! Little drops of Future made pleasing gauge faces.
Once again dear friends, Into the Breach!
The plastic surgery on RH fuselage half lent itself to a tad more dihedral on the starboard wing. and of course all the panel lines were obliterated, but ever forward, muckers! There are plenty more panel lines to obliterate!
MUHHU HAHA Haha!
