This Clown's a Joker! Serb T-34B
Written update, photos will follow. I found some bowing on the upper rear hull plate so detached one side to chamfer and see if that alleviates the issue. Cut off the Dragon roadwheel arms and replaced them with parts from a MiniArt Su-85 (I have two kits of which one has an interior) This guarantees a perfect fit to the MiniArm T-34 'Starfish' wheels. Then I only have to adapt the Trumpeter wheel if I decide on replacing the molded on hub cap so it matches Miniart's.
You can see the myriad of parts used for this. Looks horrible from within...
Yet passable from the outside. Exhausts don't reach the firewall but not visible once the air exhaust louvers are added again. They were removed to allow for painting.
Oy! Since I took the turret from the AFV Club kit, and the hull tub is a mess, I decided to graft the hull interior into the Dragon hull tub and add the AFV Club interior to the turret as at least that was guaranteed to fit. Photos incoming! I'd like to try painting some items first. Who knows! Depends on whether or not I am whisked away on another shopping trip since my son returns to University next Monday (MLK day).
OK Saúl, are you going to allow us to see a done build this year? This one is a candidate now.
You mean see a build completed this year... I can show you VERY old builds right now! :P
Actually, this is one of three projects over half done. I will need to show the soldered mud guards and the 'damage' inflicted to match the photo. You all will be the judge if I am close or spot on.
