One Down One to Go
Hey ya John , how's it going ?
Yer only sayin , " yummy zombies " cuz people that eat them will go to you to have their teeh cleaned of rancid flesh ................ cuz just brushin with Creat just won't cut it .
The Hiab is from Academy's M113 IDF fitter.
Haven't decided weather I'm gonna place it fore or aft , I'm leaning on fore .
Still needs all the hydrolic plumbing .
Not if it's pto operated or battery operated where the hydrolic resivoir , pumps , batteries , motor are located under the deck and plumbed up through the pedestal . Then only the hydrolic lines to the pistons will be visible .
I'm thinking it is PTO operated and can check the manuals, if you wish.
Allthough I could put a hydrolic resivoir on the pedestal and run lines from that to the controls and then from the controls the booms to the piston cylinders and winch .
Saul , you won't need the pto system if it's all electric run off banks of batteries .
Pto system run would still be under the decks but a longer run to the pedestal from the aft engine .
Whatever the FM is that makes it run , 95% of it will be below deck .
The M579 manual (Australian Fitter's M113) agrees that you can place it anywhere:
