MFH Brabham BT52B
Hi all, I've only just joined up to the forum, i was brought here by @paddy thread on his lovely Abarth 1000 build.
Iven been building my first MFH kit recently too so it has been very interesting to get his take on these kits.
I chose this one as my first as i thought it would be one of the easier ones (easier being comparative of course, none of these are 'easy') Turns out its not one of the easier ones, it was produced about 10 years ago and I've since learnt that MFH have refined things over the years and improved the builds a bit. Its certainly still buildable, and I'm sure all of them have little gotchas in store for you. Having said that though, its very enjoyable even if it is the hardest kit I've ever done. And I'm not very far into it yet either... :rotf
Lovely box it came in
p
First step with these is to clean the parts up and check them off to make sure you have everythiing you need. This is just the white metal parts, there are resin parts, turned parts, rubber tyres, wire etc etc. I run all my white metal parts through a magnetic tumbler, this saves an awful lot of time. Even so it still took a whole day to do all of this and bag the parts up according to instruction stages.
p
I didnt take too many pics as i wasnt planning on documenting this, but i'll take more from now on.
I decided to start with the engine first, this is made up of white metal parts and resin.
p
p
p
Still lots of wiring/tidying up to do, but certainly getting there.
Next step was the gearbox and rear suspension set up.
p
Struggled a bit with this, as it all goes together with very small pins that are a pain to handle - they tend to ping off my tweezers never to be seen again so i had to use some brass rod in a couple of places, but it wont really be visible.
Also having some issues with paint chipping off even though im using etch primer and lacquer paint. Its no big deal as it can be touched up later on. I'm treating this as a 'test' build almost, if i make mistakes then so be it, the next build will be better as i'll have more of a clue how to best go about it. Having said that though i'm hoping for an end result that looks half decent from a a few feet away...
p
p
Next step is doing the brakes. You have the choice of steel discs or carbon ceramic, i'm going with the carbon ones as i think they will look better and i think they used them more anyway.
p
And the instructions for this next stage
p
Thats where im at, its not perfect by any means but i am enjoying it. These are very expensive kits but I've probably got 45 hours so far into it and not even close to half way done.
Thanks for looking!
Looking really good Boogie! Slow assembly is not a crime. (I'm slower than many) It's the quality! That engine and drivetrain are impressive.
Just caught up here , great choice of car and a really good start, i dont think you are going to have any problem building this , you have the knack already :)
I had difficulties getting the black to key to the white metal, even with an etch primer it chips really easy, what did you use ?
Cheers guys. Paddy, I've been using Zero paints 2 part etch primer but i think the metal is so soft its not really helping much! Just need to be more careful with it i guess.
I've made a bit more progress, got the brakes painted up. Went for the carbon ceramic brakes and used Zero paints carbon ceramic textured paint, i'm pleased with how they have turned out.
p
Paddy i'm enjoying seeing your Abarth come to life, looks great!
Those discs are superb, great finish. Nothing build is modern enough to need carbon ceramic :) but you never know, one day..
Thanks Paddy!
Early 80's, the times of BIG turbos and ceramic brakes - In 'qualifying' state of tune its rumoured this 1500cc BMW engine could kick out 1000bhp. Although not for long i imagine.... Can see why it would need good brakes!
One of the problems i have had with these kits is the soft metal., I already mentioned this in relation to the stands on the motorcycles which cant actually support the weight of the bike, but a bigger problem with the cars is there are a lot more threaded/tapped holes. For example the doors on Abarth are metal and quite weighty, they are fixed via the hinge to the body via a single M1.4 x 4 self tap screw. This small thread in ultra soft metal strips before it even starts to tighten.
i have bought some M1.4 x 5 screws and have drilled the initial hole undersize at 1mm to give myself half a chance but i still cant tighten the screws and if you hang major parts like a door on a single screw its going to be a problem. The solution will probably be to glue the screw on final assembly, but that sort of defeats the whole purpose of a screw :) lucky the Brabham doesnt have doors :).
I know about Scale Hardware
They use to have a larger range of sizes and products. Is there anyone else out there doing little nuts and bolts?
Need they be functional? If not, I know quite a few.
These are the type @paddy is using with two smaller sizes included ($16USD on Amazon):
Some of these are easily obtainable on ebay
Dont know if this wiull work as its ebau UK
I just bought these and several other sizes but a good source is model railway engineering sites. Trouble is in the UK they will almost all be Imperial.. I get a lot from here
Brass is always cheaper and usually goes to a smaller size 14BA is for example about 1mm
@paddy, thanks for including the link as I was scratching my own head as to what cheesehead meant. Looks like a cheese wheel.
@Boogie Man, for some reason, your photos stopped showing. @moon puppy, any clue?
Right-clicking to show image leads to nothing, clicked on link and saw the image and even created an account there.
I tried a couple of the direct links in his original post. some work some give me a 500 error. I'm on my work computer so could be our security blocking but it really looks like it's on the hosting side.
Just did a refresh and all his images are back.
Its odd because if i click on the pic icons in his posts the pictures are there in a gallery but not in the posts.
Cheese head is as you say like a cheese its a metric thing. Metric dont use round head, they have a pan head which is like a squashed round head.
