Heavens Eagle
I like Tamiya German Grey XF-63 or Dark Yellow XF-60 (or for later in the war XF-88/89/90.
I know that Tamiya goes on the plastic and bonds well, Thanks James.
I barely remember him, then again, I barely remember yesterday. I quit using Vallejo because it would not perform like I wanted, and I ruined a good airbrush with Windex because of the ammonia. So, I just keep on with Tamiya and the other acrylic lacquers, Gunze, AK and the like.I always use a clear gloss before the stickers. Either the Alclad Aqua clear or it's clear base to have a rock solid seal coat. Vallejo needs prep work, like most paints. You gotta have a good primer for it to stick to then the right mix for thinning. A hard formula mix isn't for everyone. I remember back on the old Swannys site, think his name was John Hart @Adam and @Paulw would remember did a tutorial about thinning anything. Basically you wanted milk consistency. Vallejo, I tend to use the retarders and or windex. But since I gave my stock of Vallejo away, I only have some model colors right now, I'm not getting too worked up about it now.
Yeah Testors still makes the small paint bottles of which there are some useful colors (zinc chromate yellow!!) and apparently the Dullcoat is still profitable to make.I do believe it attacks the nickel finish in some types.
Paul...for prepping for decals I used to use Future but with it gone now I've tried the white bottle replacement but don't love it. I know AMMO is a no go for you, but I've received bottles of their Lucky varnish for reviews for AMPS and have had success.
For after decals, I still use the Testors Dullcote as I still seem to be able to grab it from Hobby Lobby.
That is pretty much what I read. I know that many acrylics are rather picky about the thinners used especially when spraying the paint. This is the first model I am doing with Vallejo for the final colors. What do you use for your primers Tim?Vallejo was the first acrylic paint I used after being forced to give up my Model Master enamel. It was a learning curve and I sure didn't like it. I finally figured out that you must use Vallejo thinner to thin their paint. Then it was getting the air pressure dailed in and putting on lighter layers. I've gotten used to it now and since I have so much Vallejo I can't let it go...haha
