The R2D (Resin 2 Detail) upgraded engines are sublime...
Not a fan of resin guns as they always seem bent to melike those ones for shooting round corners ;-). I am sure there is a way to straighten them but i never found it. It was always a problem with the resin detail kits from Eduard and Aires.
Yes, it was noted as well as the fact it is not adjustable (mine was adjustable up and down). So, I need to create a jig as I have three turrets to do!Looking at the foot rest in the photo, there are two bends. The first is jut below the mounts and looks to be about 20 degrees or so. The second is what you have and brings the lower part to the 45 degrees. Also if you look real close there appears to be a thin plate filling the lower part from the second bend down.
The plastic boxes on the top left are from Teknics, the one at top right with red cardboard header is Reheat, but I don't recall the white metal ones. Almost all the plastic figures, except André the Giant, pointing to the Reheat red label, seem to be from Monogram kits. The only kit with paratroopers was the C-47. The one on all fours to the left of the light gray giant is probably from the P-61 Black Widow kit. I see one Clark tractor driver from the Liberator kit and many from others.
