The kit is rather basic but not bad, fit is good. If you want more details i.e. inside the pit, you have get creativeThat OD looks great. How is that kit?
yep that's true and from images I've seen it does look quite nice. The only one I was able to lacate was that expensive that I decided to take it as guidance and doa litle myself.True Details used to make a cockpit set that helps a lot. Wonder if the new Squadron has the rights to TD?
Thanks Barney. I think you're mistaking me for someone else, I've been using airbrushes for 30+ years now and I use brushes alike, almost always bothGreat Job!
Are you using an Air Brush or still using a hairy stick?
Must be... I am old...Thanks a lot ya all!
