Paulw
Time for a new one on the bench. Hasegawa's J2M-3 Raiden. This has always been one of my most favorite Japanese WW II aircraft ever since I had the classic Revell one back in the early 70's. This is for a club theme build and since I thought why not on the theme build so I selected this kit. So far it is a real nice kit as far as fit and detail are concerned although I think the seat is a bit thick but other than that every thing else seems just right.
The engine will be mostly hidden by the large cooling intake plenum that is mounted to the inside of the cowl and then it secures to the engine's center hub. I chose to shoot some black primer on the cylinders and buff it out a bit with Tamiya weathering master silver. I then capped the rocker covers with aluminum, shot some dark brown on the exhausts and dry brushed some soot color from the same weathering master set.
