Banished to the Eastern (Russian) Front Diorama
Banished to the Eastern Front Diorama-The Begining
Ok thanks for all your comment Fellow modelers ..... now I'm caught up with all my constructing on the foam part other than figuring out the backside of command post ..... which I had on the shelf and a friend of mine really wanted it so I sold it to Him ...... another is already ordered ....
I've plastered in the craters ... I will be adding a top lip area around them .....
This is a shot of the tunnel leading from command post to the APC (Armored Personnel Carrier ) For :bat Ed .....
Ok time to work on the Bridge .... Has Anyone seen that confounded Bridge ???
I need to ask a question ..... Should I just continue with each model on this topic or start a new one for each one ???
Lots of stuff going on there Gerry, looking good!!
Was that a Zeppelin reference....?
Tom
Well look at what you're building and see if it falls into any of our current Campaigns.
https://www.modelersalliance.com/forum/current-campaigns
:popcorn
Tom
Thanks Tom This will take lots of time because I'm new to the Darkside ..... :ro: :dude (y) Why Yes, ... I believe it was I'm a :eek:ldguy
Banished to the Eastern Front Diorama-The Bridge
Ok so I'm a new guy here just learning the ropes So I need this one removed but I need the phots to stay in the next post ... :facepalm :tomato :smack .... there was another forum where a member could delete His own post .... But I can't find the button on this one ... :skipper
Wooden it be Nice ...... ??
Ok so now it's time for some styrene to go on the Dio .....
I built the bridge some time ago .... not a bad job ... I even added the cuts that were on the box art
It's my belief that the pontoons should look like this .....
And not like this ...... So there is a lot of sanding filing & scraping going on to remove this seam in the middle all the way around the pontoon .....
Thanks Luiz ... I do wood fairly well but have lots of trouble with other stuff ...... In a former life I was a carpenter so wood is something I know ...
I used an acrylics oil set, that included a book called acrylics for dummy's ...... I kind of glanced through the book ..... wood is easy to paint .... especially if the styrene has a nice wood gain already.....
You really love filling and sanding dontcha :yipee :yipee :yipee :geek
AMS to the Max !!! :fencing ....
These need cleaned around the rope holder thingies ..... but one is almost finished .... :eek:ldguy :gogo :hmmm
Good job, like how this is going. :popcorn
Well I tried the dremel tool ..... and you can see in one area ... there is a divot .... fill sand fill sand .... I have only started one .... may get it done tonight ... :D
Thanks MP & Luiz ..... Fixing to get after it right now .... I hope it doesn't make me late for work .... :rotf
how neat, the dugout, is it going to be filled in with something? :popcorn
yes, that area will be the command post area there will be the radio operators tent and the anti-tank gun some troops in a bunker and command post
yes, that area will be the command post area there will be the radio operators tent and the anti-tank gun some troops in a bunker and command post.
In case your wondering why the double post I was trying to fix the previous post with my android device ...... guess what no bracket on the keyboard ..... :smack :tomato
:rotf :rotf Don'cha just luv new technology!! :eek:hyeah
