what fluid you will use for blackening tracks? And what fluid you use for rust?
Roman, i will use the burnishing agent for Friul tracks from Uschi van der Rosten, i never tried it before so it will be interesting to see how it turns out.
Thanks for the heads up Ron!![]()
The tracks where first cleaned with vinegar (or azijn, as they call it in Netherlands).
so here is the startup![]()
Mix one bottle of agent with one bottle of water and then in goes the tracks :geek
Used an toothbrush to scrub the agent in to the tracks and get the airbubbles out.
here you see the difference after a couple of minutes in the agent.
Out of the bath and cleaned off under running water to get the tracks clean of the agent.
Just had to try them on before closing down tonight![]()
nothing else done to the tracks, just a bath :coolio![]()
Mats
