Thanks for the comments everyone! Glad you are enjoying this build! I know I am! Just wish I had done more earlier in the year than I did because I'm feeling the pressure to complete this before the deadline.
Crunch time! This one is going to be close!!!
Wheels and props done!
For the wheels, I used the end of a tooth pick dabbed in some Model Master semi gloss and just stuck it in the spaces of the wheel. Worked quite well!
For the props, they had their tips painted white, then yellow from before, then I air brushed them light grey and used a simple mask of a piece of tape to make the black markings. Hubs are silver.
Got the side fuselage antenna arrays on and painted.
and the props attached
Just started to give it a bit of a gloss coat tonight in a few key areas. I don't want anything to bleed. I'm going to use a spray can to gloss coat the rest tomorrow (otherwise it'll take me forever). Then decals, a little bit of a wash and weathering, a couple last fiddly bits, rigging and a dullcote. 7 days to go!!!!! :gogo
a couple overall shots....sorry the lighting sucks!
