Sherman 18
I dug out this old project, maybe I can get something going on it.
The base kit is the old DML M4A3E8 with the single pin track.
I started it years ago when I first got it and the turret did not look right. So I put it up. A couple years ago I started to mess around with it. I did a little reshaping of the turret and a started to put new cast texture to it, but it still did not look right. The hull I made some plastic boxes for the sides and front. Then covered them with A+B putty for cement armor. I like how the hull is turning out, I even started to add welds to it. On Sunday I was looking at my for gotten projects shelf and pull it out. I still don't like the turret, I found an old Italeri T23 turret in the parts box as I'm thinking of going with it.
I took some pictures of the where the project stalled as a start point.
Compairing the DML T23 turret verus Italeri one, To me the Italeri looks right
As the the two halfs the turret were drying I started to play with reshaping the DML turret again.
I'm not out anything if it does not go right, but if it does work, I have a couple more I can do and maybe save me some $
This is a shot of what the early released DML T23 turrets look like from the top
best shot I could do with my reshaped turret on the left
Not sure but still needs work to look right to me
Back to the parts box T23 turret, thought I would add the odd lift ring next to the loaders hatch (yeah I stuck it in the wrong place
Then I got the bright idea of trying some casting numbers/marks :pinch:
I used the plastic ones that you get in the Academy M36 kit
