nsmekanik
Member
This is actually a sweet little kit
and it's going together very well. I'm just cleaning things up and test fitting everything, so far the only things glued on are the final drives and the turret halves, since I'm going to leave a few of the hatches open, for some crew figures later on, before I start glueing things I'm going to give the interior a shot of gloss black.
The fit is reasonable, it has weld seem moulded on the top cover, but the fit is not good enough for it to look right so I sanded off the seam and will add my on welding bead once it's glued into place.
The rear cover is bolted on, but Hobby boss didn't define this at all, even though they did a nice job of moulding in the cutting torch marks of the rear plate, which is welded on to the back, so I scribed in a deep gap.
Everting is now set in place
I believe I'm going to have to add some welding beads to the top of the turret as well, gotta look that up
