Zimmerit help, please!
Gene
Member
Good day boys & girls,
I am planning on adding zimmerit to a Tiger I, using the hot knife method. What I need to know is approximate width of each row?
TIA!!!
Gene
GENE,
This really needs to be posted in the Help section, but to answer your Question - The Zimmerit - Use a flat tip approx. 3mm wide. That should do it. But Be Very careful with that Hot Knife.
ERIK
GENE,
CHEERS ! Show some pix of your work when you get it knocked out. Remember, You may want to run some Tamiya Super-Thin Cement over the Zimm , to soften it up a bit.
ERIK
