ModelMakerZ
Has now released the T-34t conversion for the iconic T-34 main battle tank. In the early days of the T-34 there was not a standard vehicle capable of doing recovery operations, on heavier vehicles such as the T-34. Soviet ingenuity came to the rescue with the T-34 tractor. It was ingenious in its simplicity. The turret was removed and a bolted plate was added with a cupola and a vision block. Being in the same power and weight class the T-34 tractor was a capable tool for recovery operations as well as towing artillery.
The ModelMakerZ conversion is a one piece drop in designed around the Dragon T-34 kit. It is a no cut conversion (meaning no cutting is required on the T-34 chassis).This conversion is an excellent first resin conversion or for the master modeler as well. It is cast in a pure white resin, so it will take a base color without distorting the hue of the finished paint. These vehicles have been used from the early days of the Second World War through the Afghan war.
www.modelmakerz.net
www.modelmakerz.net
