PZL.23A Karas (1/48 Mirage)
Making some progress with this.
I ordered the PART exterior PE set for this and it seems to have a lot of duplicated parts that were already included with the kit. In some cases, the kit parts look better. For instance, the wing parts, I ended up using the kit supplied PE as it was wider and had more detail.
Started the landing gear PE, there are quite a few parts to this and I've decided to go with un-spatted gear.
The prop hub, this will be entirely covered in PE panels when done
One wing attached and PE added, I used a rivet tool to make rivets in the wing and body. One side done!
The kit is well molded but a few pieces suffer from severe sink marks, like the prop pieces
and finally, I just added some braces to the inside of the wings to give them some strength.
Coming along nicely Warren (y) (y) (y) I love this peculiar little bird .
Hard to believe but that prop actually looks worse that the ones on my little Widgeon :blink
Good luck, Christian B)
still poking away at this one. Added more PE and made a test fit of the body on the wings.
The interior will fit nice. It is busy and I still have more detail to add.
