I picked this up at the 2009 Nationals, and finally got around to building it. It's the 1/350 Trumpeter S-100 Schnellboat. It's a pretty nice kit, although there is a bit of room for improvement.
I added PE railing, a scratch built brass blast shield on the center gun, and added all the framing for the tarps [and the "rope"]. The camo scheme was not easy. I tried painting it, and failed. So I ended up using Prismacolor pencils. The PE base comes with the kit, and I added that to a stained balsa wood base. The screws are PE from the kit, as is the rear gun's blast shield. Not much else to say. I packed as much detail into it as I could, given the SUPER small size.
