Help with Mr Surfacer
IainS
New member
I am doing a Tamyia Panzer II C and am using some Mr Surfacer to fill in a few small gaps. I read on the net that you use a paint brush to spread the very fine Mr Surfacer 1200 but if so how do you clean the brush? Is there some other method?
yours
Iain
Ive cleaned my brush up before with Mineral spirit,... seemed to work ok
I didnt use one of my good brushes though only a cheapo one from a cheapo set
A
Lacquer thinner is what I prefer to use to clean up. To clean up dried Mr. Surfacer on the plastic, use 91% alcohol.
Check with Swanny's for the full story on how to work with Mr. Surfacer.
http://www.swannysmodels.com/Surfacer.html
just to throw it out there i have used MR Color thinner too it works well i use the micro brush brand for the application brush it sops up and paints the right layer amounts too good luck!
