Dude, looks like you're about half way in on this build. Tell ya what, promise me you'll do another completely unbuilt kit for the Charlie Don't Surf before the end of the build and we'll not say anything to anyone about this, OK?
Alright then, but still, with a full year on this GB, we ought to be able to get another build out of ya.![]()
Chad,
From the looks of it, the sighting rifle's mount is causing the trouble. See how the spotting rifle is drooping far worse than the barrel?
I cam across this as well. I cut a ring of styrene tube (drilled out) and placed it under the front spotting rifle mount to remedy this.
sharkmouth wrote:
Chad,
Thanks for the tip Saul.I am debating on not to replace the Academy 106 barrel in the M151 version, This is a barrel where you need three hands.![]()
General Zod wrote:
sharkmouth wrote:
Chad,
Hey there General Zod!
If you want one, I can send you an AFV Club 106mm recoilless rifle with 8 rounds of ammo.
Box art here: http://www.militaryhobbies.ca/custom/productzoom/afv35021.jpg
Let me know if this will help you.
Cheers from Peter
Tamiya OD paint on.I still can't get that metal barrel looking right. When I get home next week,I will use the 106 from the anti tank set.
Hi there General Zod.
Is there any way you could put a length of tubing inside that metal barrel to align it?
Cheers from Peter
