For sure but I need to finish a few more details first as well as adding the ZimmeritAre you doing the shell holes as well?
Nice, so you'd think I could dial down the temp on my Hakko soldering station and get the same effect. Of course it would toast the tip, i'll get one dedicated to plastic.Defined more accurately as a Pyrograve pen that I use for weld and welding plastic strips into gaps. Got this direct from Historex in 1994(England) and it has 'never missed a beat'.
You won't regret it. I find it really handy for heaps of things.Nice, so you'd think I could dial down the temp on my Hakko soldering station and get the same effect. Of course it would toast the tip, i'll get one dedicated to plastic.
It was probaly from a JS2 at reasonably close range.I'm trying to imagine what round hit the mantlet to just punch right through it? This is looking quite wrecked per your usual idiom!
British vehicles, including those Alecto A25 E2 SPGs, which has me wondering why an IS2 would be engaging the dug in tank.Anyone know what those 8 wheeled tracked vehicles are trundling down the middle of the street?
I would guess this is post war and those Alecto I SPGs were in the British sector. The Russians did most of the encirclement and destruction of Berlin so its conceivable a JS1 02, T34/85, or SU 85/90/120 got the kill on this makeshift defensive point.British vehicles, including those Alecto A25 E2 SPGs, which has me wondering why an IS2 would be engaging the dug in tank.
Would that be a version of the Christie suspension system?The picture shows the 11th Hussars, 7th Armored Division's reconnaisance regiment, in Berlin in the summer of 1945. They had received two Alecto I's in June 1945. The plan in late 1944 was that each reconnaisance regiment would receive 4 vehicles. Production delays meant none reached units until June 1945. British units used them post-war in Germany and Palistine until 1955. None survived the scrap yard.
They were derived from the Tetrach airborne tank. They were armed with a 95mm howitzer firing HEAT or Smoke shells. The maximum on road speed was 50km/h.
RichB
Its a Vickers-Armstrong version. The Alecto used a skid steer system, the two centre roads wheels bowing the track.Would that be a version of the Christie suspension system?
Why not? IIf its 500m down the road, line it up and knock it out. The JS2's were hunting down some skinny streets in Berlin but this one is quite wide and a perfect street for long distance tank engagement.British vehicles, including those Alecto A25 E2 SPGs, which has me wondering why an IS2 would be engaging the dug in tank.
If the image is post-war, then it is very plausible. Is your scene post-war?Why not?
Yes, I will be setting mine in the first few weeks after the surrender in Late May 1945If the image is post-war, then it is very plausible. Is your scene post-war?
