Wingnut Wings Sopwith Triplane
OK, I'm happy with the color!
Need another coat maybe, got some brown showing through. I mixed 4 parts Tamiya OD with 1 part Tamiya red brown. The preshade is...brown.
Wings need more work, I was trying to keep the ribs lighter but in the photos it look more like the primer coming through.
@Brokeneagle
Here's some photos
Not much but there's a start. I'm perplex about the floor. Instructions call for both Irish Linen and Aluminum. Right now it's aluminum.
Searching around what others have done for PC10 or PC12 I've seen every shade of brown and green out there so who's going to tell me I'm wrong?
Primer, tamiya black for preshade, then Nato Brown next layer, then a thin coat of Tamiya Olive Drab. FX 62.
What you see on the far right is just the xf62 over primer and preshade. From the wingtip to about the mid section is the brown backed basecoat.
After some clear coats and weathering, protecting the rib tap I think this will work.
I think this looks excellent 👌
Are you sure you want the ribs lighter? No light can get through there, like it can especially when the lower surfaces are only clear dope. I suppose it can depend on the lighting.
I gotta get the masking tighter. looking around for something to use as a template maybe so it'll be consistent.
Just do one stripe of tape in the width you need, glue that on to the rip and then mask left and right, then the next rip and so on - at least that is what I would do
