Oh no...I got the green acres theme in my head now.
I'm getting my wife a shirt that says "I ride a Red Belly"I've replaced the spark plugs. Removed and cleaned the oil bath air cleaner (that's a fascinating piece of hardware) Fixed the stuck carburetor float, re-bent the gas line from the sediment bowl to the carb. These are gravity fed engines and somebody had an up hill bend in the line. The carb's main needle valve was turned way. Set it back to 2 turns out. I adjusted the timing. I suspect the old distributor is tired so I have a new one on the way. The one in it is a Prestolite, not original to the 1951 Ford.
The engine has smoothed out and doesn't backfire.
I think the tractor is ready to work, till something breaks.View attachment 181707
With all the rain we've had here the grass better be green! I think we broke a record for rainfall in the month of May. We don't have nice grass in our yard. The 3 acres of mowed yard grass is just the plain pasture kind, it was a cow field before my wife had the house built.Excellent, pretty cool photo also Tim. Nice green grass and rust.
It's my OCDYou're going to start messing with the wiring on something that's working? OK then...![]()
