Trumpeter 1/48 Cessna A-37B Dragonfly
Steve Ski
24th CAMS, Howard AFB, Panama, Call sign, Tweety.
It’s been quite some time since I’ve worked an AC build, quit some time. After looking at what some folks are doing to their kits, I already know this kit is not up to snuff in detail, but I’ll work it as best as I can. Most of you already know this is a bit out of my norm, there ain’t no figures, sheesh! Lol. In 1/48th scale, I wouldn’t be wanting to work em anyway. Honestly, I would have preferred a 1/32 scale build, especially on this little rocket, but to no avail. I highly doubt we’ll ever see Tweety in anything bigger than 1/48 scale, no call for it.
Regardless, this was a requested build from my former Weapons Shop Chief in Panama. So, here’s to ya, Brother Richie, off we go! Funny, he said I was the fastest, but not necessarily the safest, load-crew chief. I don’t get it,…… lol.
Ya, you guessed it,……that was long ago, back in 85-87. Good times, I remember. It was a two-year beach party, but somebody had ta do it, right? This was also a great little bird to work on, until you had to work the bomb racks. Yes, keep the Preparation-H close by, especially at 6’-1” tall. I will tell you, from personal experience, that when one of our Tweety’s was attacked by the Panamanian Air Force, it was a messy job to clean up. If I remember the season correctly, bird strikes by vultures were not uncommon during the dry season. It was always amazed at the number of vultures that would fill the sky, and the clean-up reeked something fierce!
Ok, enough background, let’s check out this Trumpeter kit. First off, the kit did get decent reviews, but I have seen prior kits like Encore (Monogram/Revell) with much better detail. Sadly, the Encore kit from 2012 included the decals specifically for Howard AFB, Panama, but is no longer available. I really do need those decals, huh, hummmm! That kit, I understand, even had resin parts, but I could be mistaken, and the actual rocket pods we loaded, the LAU-???. Like I’m supposed to remember that? Yes, I loaded those rocket pods, but were they the LAU-68, 48? I don’t remember. I’ve had two incentive rides in this little Tweety, but I don’t recall every aspect of that cockpit either, HA! This was a fun bird to fly, btw, leme tell ya.
The Trumpeter cockpit is pretty weak on detail, so I am adding what I can. It’s not a show stopper, just a bit more work to get decent results. After all, who hasn’t had to refab, convert, or scratch build parts or details? It’s part of the fun, IMHO, so it’s not really a big deal for me.
The instructions for this kit are very basic, very simple, because, well,……..this is a very simple kit. I found the mold work is very good and the fuselage fits together cleanly, no hassles. Everything fits as it should, one for Trumpeter, and nothing was a headache at all, so far. My biggest concern is getting parts pre-painted in the proper sequence. I’m keeping close tabs on the assembly order to avoid any redoes.
Not clearly seen is the putty I crammed into the nose, above the wheel well, which is the ballast for the down gear position. Very kind of them to remind a non-standard bird builder. That’s two for Trumpeter! Only thing, I hope it’s enough weight, HA!
I was getting antsy to get the cockpit enclosed so I could add minor details where they would be visible. There’s a lot of working space behind the ejection seats, which helps a bit. The instrument panel has some decent raised details, but why would you use decals for a raised detailed instrument panel? I had to use more than a bit of Micro Sol to get some of them to indent, and somehow my fingers must have touched the main flight instrument decal, because when I went to dap some MS on it, it was gone, woof! Aaaah, I couldn’t stop laughing, how much of a bozo does one need to be when working such tiny details? Don’t answer that. No worries, I broke out my “Tartan” brushes, that’s a 0000 Windsor & Newton fine point, btw, and got to work using some excellent reference photos. I think I did the panel justice for being so dang tiny.
This will end up being in the open cockpit configuration, so I will be adding pins and “Remove Before Flight” flagging where appropriate. Any detail I can glean from my reference photos and be able to fabricate, I will. The oxygen hoses are seen below, one installed, the other in process. I used some very thin copper wire coiled around a sewing pin, then I slipped stretched sprue through and lightly heated it to form it. There’s also a few cables and connection hoses in some of the photos, but one will get the point across well enough as that portion is tight on space. Also, the throttle side switch will be added. I can’t remember if that was the trim tab button, not sure.
After the oxygen hoses are completed, I will work the ejection seat piston dead center rear, another detail missing by Trumpeter. It has a brass-colored shaft, black top portion with small cables. I will work in whatever I can with the limited space available. I think Trumpeter could have done a more thorough job of replicating these ejection seats, though. That’s one demerit for Trumpeter!
So, we’re up and running, more to follow soon. Please holler, you bird builders especially, if you see anything needing attention, I’m all ears.
Thanks for watchin. Cheers, Ski.
This is one of the birds I had to stop myself from starting as I got the Trumpeter kit and realized it relied HEAVILY on the old Monogram kit. I'm glad you didn't ask for references as I have LOADS!
The Tweety birds I want in my collection:
Rocket pod for the 72nd scale one...
Impressive I/P! No other airplane nut needs to tell YOU why A-37's are called "Tweets"
Are you remembering the tiny drops of future for the gauge faces?
What does the silver tube poking out of the starboard side of the nose do?
Cover for the minigun. I mentioned that in my photo review of the Trumpeter kit here. Included are comparisons to the Monogram kit.
@Steve Ski, is the central piston located between the seats? If so, this is the canopy piston. As I wrote, I have a lot of information on this subject.
Oh, I had that Encore kit, the resin didn't fit the cockpit. HUGE gap. Not sure I still have the kit or decals but will look. I don't think I would have ditched the decals. @iambrb didn't you start the Encore kit also?
Thanks for the comments, Gents, much appreciated.
Rocket pod for the 72nd scale one...View attachment 180648
Thanks for the ref pics, Brother! This last one is closer to the actual camo pattern on the Howard birds, no tan at all. After working F-15's loading aim-9's and 7's, this was a strange little thing to behold.
The future is for canopy polish, etc. I probably won't bother with the instrument glass; it won't be seen much. Yes, the silver pipe is the nose protection for the Gau-2 mini-gun. It always struck me as a cheap metal shop quick fabrication, as it looks like serious after-market weekender scratch work, but it does work.
Yes, the central piston is the canopy cylinder, as the ejection seats each have a piston in the center back middle.
There are actually two, one more slender than the other, but I will only be working the larger cylinder. This pic below is for reference only.
Holy Cow! Please tell me the dial faces are decals. That's one sharp IP man.
Load crew chief? You were a knuckle dragger bomb loader?
Most of those dials and instruments are hand painted. The decals became too difficult to settle down, so the decals that survived have basically been painted over or touched up a little. There is one section I left alone, middle right pnl, 4 glass section, that is a decal. some of the main flight instruments need touch up, for sure.
Aircraft Armament Systems Specialist, 46270, aircraft weapons systems maintenance, as they used to say. Not a knuckle dragger, but a muzzle plugger, bomb loader.
Very nice cockpit detail. Gary S.
Thanks, Gary. I've toned down the wash, it appears to look like "rust" in these pics. That is unacceptable, imho, lol.
MP, if you've got those decals and they are still viable I would gladly pay you for them, shipping and all. As it stands right now, I have to refab my own in word, if possible, and even use an inet copy and repaint each and every detail, to remove the blue backdrop, before attempting to copy and print to decal paper. I'm not sure if I'm going to have much success, my printer is not the greatest.
Please let me know, MP, I'll give you my first born, wife, kids, and all, HA!
I have a lovely 1/48 Monogram kit in stock. :bigrin:
Brother, if you find the decal set I need I'll swap ya for what came in this kit. I'll pay for any postage, most certainly.
Thanks for the encouragement, Gents. And please, if anybody finds the Howards AFB decal set, I will gladly pay for them, shipping, too, if you're willing to cut loose with them.
After I get the cockpit dialed in, on to the wings, etc. This is a super easy build with a lot of potential, but I just might want to scratch the LAU-68 rocket launchers; they shouldn't be too difficult, right?
I was 46250! 2 man on B52 load crew. I loaded nukes at GFAFB early 80s. Quickly found out North Dakota was not my thing, probably could have done USAF but not ND!
I'm looking, hope I have them. Rattling @iambrb cage again.
The brass colored one is the hydraulic piston and the dark one is a guide. I have the manuals. It seems that you are interested in the observation variant; OA-37. I never got the Encore kit but may have leftover decals from Trumpeter and Monogram.
Lol, you poor bugger! The old "No Lone Zone!" I'm so glad I made the F-15 team, HA! Ya, Holloman wasn't a dandy either, but I ended up staying there a total of 13yrs, met me lovely bride and joined the US Professional Rugby team there as well. So, it all worked out.
I almost stayed the full 6yrs, but took the early out in '88 to finish school and try for a pilot slot, also did Guard and Reserve duty. I never got the slot, but the journey was worth every minute of it, the best time of my life pushing for that goal. So, when someone says "it's the journey, not necessarily the destination," I concur.
Did you punch out after 4 and was the buff your only bird? I got to work the F-15, 16, A-7, A-37, Uh-1N, O-2, T-38, and even got my hands on an A-10 once, HA! I really enjoyed my time in, though it was not always a party, but I sure did love working for the Gipper. When Slick Willy came along, I punched out for obvious reasons!
Excellent, you got the manual, good to have for sure, and where did you run across that little gem? So, the piston is hydraulic, probably for seat adjustment, but I'll be adding that, just the wrong nomenclature. Not the OA, but A is what I'm after. These were not OA in Panama as far as I remember, only the attack variant. I could be wrong; it's only been 40 years. Dang, did I just say 40yrs? Sheesh! Where the heck did the time go and who wound that clock too tight? I'd really like to know. Never mind, I know.
This is the decal set I am looking for, but has both OA and A, as per the title.
I've got the F-15 manual myself, but that's for a later project. Any corrections needed that you see, I'm all ears, Brother, and thanks for the heads up.
P.S. I'd have to talk with my shop chief, he'd know, cause we always had the Willy Petes for spotting, so you are probably correct, OA. My old boss is like an elephant, he remembers eeeverything.
Most of my manuals are gifts from base visits. Some from evilBay..
The TACP of the 24th SOW did fly A-37Bs at Howard. The WP was also used in 'Nam before the OA-37B. I can definitely be wrong and love learning, simply ask @moon puppy who provided information about a Thunderbolt which I did not know.
If I find the boxes 📦 I will check for the decals. Is there anything you need from the manuals?
I punched earlier than that, long sad story but has mostly to do with me being too immature and it a bad location. Yep, Buffs were the only aircraft. I had orders going through Lowry to go to Waner Robins which would have been 3 hours from home. Not sure if that would have been good or bad but it wouldn't have been ND. Last day at Lowry I got orders changed to GF... :bash:
Like they say, I'll be damned if I'd do it again but I did enjoy the experience.
Your painting skills on the IP are off the chart! :notworthy
Ok that is some neat stuff!!!
That Colombian A-37 paint scheme is just too kewl
Lemme figger put why Pup is mentioning me
If that means what I think it means...
Didn't you start this kit also?
NVM, you texted me the answer. Nothing like having a conversation over different platforms. :frantic:
