hamchuck
Hello all,
I posted an introduction some months ago but haven't since. Part of that is because I was working on a Beaufighter than met a tragic end at the hands (paws?) of our cats. So, I went to this B-25.
It's my first Eduard kit and my first time working with photoetch. I've been enjoying it immensely, though I mangled one of the PE pieces when I joined the fuselage halves together. Happily it's on the bottom where it won't be visible.
The build sequence requires installing the nose gear before the fuselage halves are joined. I was uncomfortable with this and sure enough I broke the nose gear. I had to fix it with a micro-drill and thin music wire.
This is also my first time doing pre-shading and chipping to this degree. I had some trouble while I was decaling. I don't think I got the gloss coat on thick enough to protect the delicate Vallejo acrylic. It started to eat through in spots and I also had some trouble on the fuselage roundel where it had to snug down over some protrusions. That was today, so I decided to quit for now instead working while frustrated. I'll fix the spots and lay on some more gloss tomorrow, decal probably the next day. Then, weathering.
