DAS WERK DW35007 - 1:35 Panzerkleinzerstörer Rutscher
Boxart and contents
Well just an update for you all.
for a little tank its a massive pain in the arris followed by one mahoooosive schoolboy error.
Firstly the model itself is ok but the details are weak so a lot of improvements were made
heres the tank as we are now followed by further pics and explanations
In this photo i changed the mud guards as they were way too think and the headlight was warped so i got rid if it you can also see the front tow hook which was incredily thin so as per the nightshift series on you tube i made it thickerer
Ok so youre wondering about the schoolboy error
who on earth cements the super structure together without mounting the gun,...yep its me :silly: so anyway ages of padding the roof section i finally got it to fit :rolleyes:
surface was textured using thin cement and stippled with stiff brush and weld seams enhanced with stretch sprue. Old verlinden hex bolt heads were added
heavily stippled exhaust and a larger pipe put on to replace the one that twanged off into outter space
last pic today another example of front flap i havnt bothered to clean up the supa glue as there will be crap all over as the setting will be Berlin in the final days
