Looks good with the cockpit. I seem to see what you are talking about on the scribing for the ammo and gun access panels. In the photos of the actual plane the panels look to be fully rectangular. The scribing along the rear of the panel angles in the part. It looks to be angled so that the outer rear corner of the ammo hatch is further back than the rear corner by the guns.
The other thing could be that what I see could just be the changing curvatures on the wing as the chord gets shorter. Also the one photo with the panels elevated slightly gives the slight angle difference on the rear edge.
I would measure it to make sure it isn't an optical delusionand check some other references
The choice is to either leave it or take some slightly stretched sprue and using CA full the line and rescribe it parallel to the front edge of the panel.
Either way is good, just up to what you think it should be.
