Paulw
I have always been looking to get hobby and modeling supplies with out paying out the nose with internet prices being what they are so I thought I would share some of the things that I buy and use exclusively.
You may recognize some of them and I doubt that our friends from over seas may have such things available to them but maybe they have it by a different name.
One of the many products that we all use at one time or another is good ole Tamiya Extra thin cement. This comes in a 40ml bottle and usually runs from 4 to 7 dollars depending on where you are. This is a mixture of MEK, TCE and other chemicals of which I can not remember right now. Now here is a product that has the same chemicals (solvents) that is in the Tamiya product but at 118 ml and $2.00 a bottle is a better bargain all around. Beauty secrets fingernail polish thinner. The operative word here is thinner and not remover.
This stuff goes into the empty Tamiya bottle and you have about three times the use from one bottle that you have with the Tamiya product. The only time I buy the Tamiya stuff is when I need a new applicator brush.
The next product is something a watch maker friend of mine turned me on too last year and I find it a grand substitute for Tenax and Plas-T-Weld.
This stuff comes in all sizes and viscosities. It is just as hot as Tenax and the other but with a 4 oz. can you get almost forever use out of. Scigrip Weld-On #3 very fast set and I mean very fast set. Mine came with an applicator bottle but that bottle is for more of an industrial application.
I took Same said friends advice and bought a better set of tweezers of which I paid about $15.00 shipped from eBay. They are the surgical and jewelers type and came in a nifty storage case.
It has all kinds of uses here.
The next item are sanding sticks. I get mine from the same beauty supply store that I buy my "Xtra Thin" from and they run about one to two dollars less than model designated sanding sticks.
These come in all kinds of grit sizes from real coarse to extra fine and you can even get some chamois buffing ones that I use for polishing canopies. I understand that there may be a need to get into fine and small areas so I just get the mini sanding sticks from Flex-i-file or Alpha Abrasives.
I needed a new set of saw blades that I can use for any resin so RB productions had this set at Sprue Brothers at a good price. The only reason I don't cut up those nail boards is because I have no safe way to do so but I am content to buy from other souses.
The saw blades fit in a small Xacto handle or you can buy a set of pe handles that are proprietary to the saw blades.
There you have it. All in a nut shell. If you have any things that you use to cut the cost of the hobby bill or anything that may be a handy item please share, we would be grateful to hear of it.
