Yes.
All the above. And someone check me if I'm wrong because I'm not that good with pigments. But you can apply the dry pigments then airbrush the fixer to hold them in place, or mix pigments with the fixer and apply wet.
Think of it this way, the pigments are sort of the same as the pigments in the bottom of an unshaken jar of paint. The other stuff is the fixer or carrier medium. Medium is the term used in art if I'm not mistaken. The way I understand it is the Fixer is just another medium for the pigments.
That help?? :idonno
You can also create heavy dust applications by scrubbing the dry pigment into the paint, and then gently airbrushing the Tamiya X-20A thinner fixer on top.
That is me as well.Must work on gentle....
Thanks for the lonk Tom.Hi Zod
Some good info here:
http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=202078&page=1
See Rinaldi's post
Tom
So I understand the MIG Pigment Fixer. I brush that stuff on,then apply the pigments? Can I brush wet pigment on,or only dry?
Thanks for the tips Ron. Would the finger or Q tip method make the pigments stick on better than a brush?![]()
