wds
Yes, this one.
This one has occupied top queen status in my court for some time.
I think I have had this kit going on twenty years. I used the line drawings from the instructions as a reference to draw panel lines in Sharpies on a RC slope glider that I built at least 18 years ago.
I think that I glued the fuselage sides together, glued the landing gear into the wheel wells, and then put it back in the box where it slept till now. I worked on painting the cockpit at the same time that I was working on the Me109 recently finished and posted here.
I encountered a small gap in the joint between the top of the wing and the fuse at wing root. Seems to be a fairly common problem on a lot of models. I didn’t want to try and fill it with putty and sand it. I found that I could support the wing tips from underneath and push down on the top of the fuse to close the gap, but I could see a disaster there as well. I solved it by spreading the fuse with some scrap sprue. I had to glue in some blocks first so that the spreader bars could push on something flat (being that the point that I wanted to spread it is at the curved wing root. Picture =1000 words.
Thanks for looking.
Bill
Thanks for looking.
Bill
