Time here has been very hard to come by since my last update but I keep plodding along as best I can
All the decals , mostly from the spare box have been applied . No problems there.
The squadron insignia was troublesome and I had no decals large enough to replace the lower wing crosses
I first coated them with Micro decal film so they would not disintegrate but that turned the black gray.( ??? )
I then used the micro sol/set and when that failed to work I tried mark softener/setter . To no avail.
After that fiasco, I tried something I have read about ( in good faith ) :zen
I applied Future over and under the decals and in due time it worked
The other side laid down good but this one still shows some wrinkles . In retrospect, the next time I will go straight for the Future. Worse ever !
I will probably have to hunt for a replacement for this one
In the mean time I assembled and painted the props ( :S ) and made some brass exhaust pipes and hung the door .
Since then I have laid down some oils but the top ones still need another overnight to be dry enough.
I think now I'll attempt to build some turrets :facepalm
Thanks for looking , Christian B)
