Sherman 18
I started this kit as a step by step for the local club's FB page. This is an old kit by todays standards, but I think it still looks like a M4A1. I believe there is an issue with the upper hull around the drivers and co-drivers hatches, not enough for me to worry about. I again had started this 4/5 years ago, I did not pay attention to my research as I discovered when I restarted it. :idonno It's just a model it can be fixed
hyeah
the kit
and what I found when took the parts back out of the box, really the only things I did wrong was add the sand shield mounting strip and the add on cheek armor
I started redoing the casting texture on the kit supplied turret and adding in some mold lines and such.
Leaving the cheek armor on the turret while it should not be there, started to bug me. I ended up trading it with one from the parts box.
On the upper hull I removed the casting symbol and plugged holes for the tools with stretched sprue
I added some casting number to the suspension from Archer
I added some missing bolts with ones from Grandt Line to the lower hull
Starting to look like a tank now
the kit
