Military Bulldozer X3
Military Bulldozer
Crawler with Nato Black. think I have thinned my Nato Black just a touch to much..
Nice treadplate PE. Instructions said to install the control levers and stuff then finesse the floor around it, I couldn't see anyway of doing that so I'm leaving the plate floating for right now till I get everything installed. The PE Plate is optional but you have to do some surgery to the kit part to get some plastic on there. I wish they had supplied full PE replacement, itching to do some soldering somewhere.
Got the safety covers over the running gear. Nice heavy coil spring (for the track tensioner) comes with the kit but if you use the safety plates no need in using it.
:soldier
Military Bulldozer
Very nice Bob :good:
I would say reload the Nato black and do another round :frantic
Military Bulldozer
Starting to look like a Dozer
:soldier
Tracks
Tracks are going together but not well. See how they warp and curve. The alignment pins and holes for the link gear have a good bit of play so they are not exactly consistent. I've learned to apply pressure to the rear of the track while I hit it with the glue but it's not helping much. I checked Friuls but they don't have any.
Military Bulldozer
Looking GOOD ,
:eek:ldguy I would like to get the armored version when it comes out (over here)
Military Bulldozer
I'm thinking the length will straighten out when you install them. If you dirty them up, will anyone be able to tell? :drinks
Military Bulldozer
OK I need suggestions.
Notice the muffler. Now notice the straight pipe that comes with the kit. How would you scratch build that muffler?
:popcorn
Military Bulldozer
Got any old rocket launchers in 1/48 lying around Maybe with old 1/48 fuel tanks for the top and bottom hemispheres
Military Bulldozer
:popcorn
Ok, what does the kit muffler look like? and a size comparison to go with it... I'm thinking a small pill bottle & a pen casing...
Military Bulldozer
Sheet styrene MP .... cut the end pieces (ovals) then laying the sheet over the top cut holes for tailpipe and stick it through .... sand edges to bevel ... or look for a 1/24 muffler from a Car kit ... & modify ... :soldier :soldier :soldier
