Re: CTA Entry - Phil - Revell B-25J Gun Nose
Thanks MP and Luiz :drinks
Rear gun in place, I will add the barrels and rear cover after painting
You get moulded seatbelts on the kit, but a seated pilot so he will hide one!!
A little more to be done on him yet
The top turret wouldn't rotate with the shell collection bags fouling on the added parts around the fuse, so a nip and tuck = a rotating turret.
The gun elevation was not good either, it just flopped down as no real support for the cradle, so a few bits of scrap plastic rod glued on top where the gun cradle sat. and two pieces of cut off plastic barrel glued into the mounting space fixed this, now the gun stays at the angle you want it.
added some pieces of .50 cal Pe ammo belts over the moulded belts
A few more pieces to glue in then a bit of planning before I commit to closing it up
