Sherman IIa in work.
The Zod
Dragon kit from some years ago. This will be done up as a Polish 1st Armoured Division.
Did the grab handles,changed tow of the tools with a bigger strap,the copper colored one. Added the gasoline and lubricating oil tabs. Took off the tow cable. Removed the two fuel caps that are not supposed to be there.and puttied the holes.
Thanks everyone. I just wish I knew the particular tank had which T23 turret. :idonno There are three different T23 turrets that had the split loader's hatch. Got some more work done today,
Pics of the real tanks. Thank you for them Saul. :good:
Looks like a .30 cal. on the loader's hatch?
Got some more work done today. The turret will be the PSC-44-1. I tried to make the holder for the cooling jacket for the .50 from the PE set I have. Not happening. :bang head I have some plastic ones at home.
Not sure if these casting marks are correct for the mantlet.
The hull will be the PSC 44-2 hull. No cover for the exhaust blower. I hope the way the tow cable lays on the front is correct. It looks like it is per The Son of Sherman book. :idonno
