Gaz 67B with Officers and equipment
Phil
this is a nice kit, will go great with the IL2 on a Russian dio board, here's the start up pics
DSC_0291r1.jpg~original
DSC_0296r1.jpg~original
Cheers Terry,
although he didn't see that 88mm shell at the end!!!!!
not sure if the windscreen folds down like the US Jeep!
went together well, a few nasty injector pin marks that could be seen inside, got rid of those, join marks around each tyre, I painted the white ID stripe instead of using Tamiya's decal, a bit thick for my taste.
starting the figures now.
Teaser........ figs are very close!!! :yipee
small dio display board to come as well :drinks
Finished painting the figs tonight, next is flat coat and a light wash to bring out the face details and some light effects over the uniforms.
DSC_0327f.jpg~original
DSC_0328f.jpg~original
DSC_0330f.jpg~original
Calling this one finished - although I do need a product to do the faces better, all I have are two black washes that are a little too dark! -
and something that would suit the 48th figure scale with a very fine particle/pigment.
DSC_0335R.jpg~original
DSC_0344R.jpg~original
DSC_0342R.jpg~original
DSC_0340R.jpg~original
There were heaps of additional equipment with the set so I made up a box from evergreen strips and filled it with ''needed supplies''
DSC_0341R.jpg~original
It's a fun little kit, to give you scale,
DSC_0345R.jpg~original
added the Il-2
DSC_0347R.jpg~original
DSC_0350R2.jpg~original
DSC_0352R.jpg~original
