Big Vietnamese Cobra Pit Placeholder for ICM 32nd Scale AH-1G x4 Build
Information Overload
Staff member
Looking at all the AH-1G references I posted, I plan to drop in once in a while for these three four Cobras. Click images to go to project page.
Early conversion subject is a 'Calico Cat scheme' AH-1G 66-15273 AH-1G D Troop, 1st Squadron, 10th Cavalry Regiment
Mid is AH-1G The Great Spekled Bird, 67-15798, C Troop, 16 Cav, which is unique in having the 20mm M35 gun, minigun pod as counterbalance and twin miniguns in the M28 turret
This is our friend, AH-1G 68-15012, #1 De Me Mi, with the Centaur added.
Fourth Cobra is of our own Gary, @centaur567. AH-1G 67-15567 The Henchman II:
Well, my third choice, #1 Du Me Mi, will be replaced by our own Gary's ride: The Henchman II 67-15567:
The decal sheet supposedly for this ship is on its way to me (ASK32019 Kentaur (sic)Pt. 2)
Why the change? @centaur567 pointed out that The Henchman II had a tongue (not included in the sheet).
Note that the sheet has the artwork for AH-1G #67-15827. “The Henchman" D troop 3/4 Cav 1970. Piloted by CW2 Thomas Olssen and maintained by Gary.
Too bad you might not have the original. The cropped image is tiny and blowing it up I get this... but we do have the earlier rendition for colors so I simply need to adapt to te shape of the second rendition.
Hubert has let me know that I have a new Special Hobby 32nd scale and KP 72nd scale Cobras (from AZ Models' mold which is more accurate in shape than Special Hobby) coming so... I have the ability to choose one more each in each scale!
So, #1 Du Me Mi is coming back...
The transmission was silver and the mount zinc chromate, swash plate dark metallic gray, push rods dark green, particle separator light gray, main rotor mast was a goldish silver, and the 7 shot rocket pods that had individual tubes were a brass dark green. Gary S.
Well, looking at the manuals, I see that I also have to cut down the starboard consoles as they also were lower than depicted by the new mold kits. Although, they are not as low as the port side consoles.
Do you know which 1/32nd scale AH-1G Cobra kit got it right over fifty years ago?
The Czech aftermarket doesn't address this as Eduard simply is now known to provide pretty makeup for kits and not corrections. Special Hobby, working with CMK, had the opportunity with all the added PE, resin and 3D printed items but didn't. Fortunately, the two Ukrainian companies (Metallic Details from Dnipro and Micro Details from Sevastopol in occupied Crimea) both address the issue.
Special Hobby includes these nice resin seats but they look strange, I will need to cut out the section from the gunner's ceramic seat to match the period photo which, as @centaur567 stated, should have the blue tinted canopy for The Henchman II:
I am glad I was busy futzing with the Cobra hatchlings and decided to look at the early air vents used before the ECS (Environmental Control System) upgrade since I also need it for the ex-NETT 'Calico Cat' Cobra AH-1G 66-15273 AH-1G D Troop, 1st Squadron, 10th Cavalry Regiment
I decided to look at the gunner's ceramic seat and... It looks like the Super Hobby seat! So the seat goes from The Henchman II to the 'Calico Cat'
I'll manually detail the kit seats (not a big deal since I have the manuals).
Double DOH!
The Special Hobby seats are made up! While detailing the kit seats, I took a much longer look at the TM illustrations and it turns out that there is ALWAYS a cutout between the ears. The seat belts from the co-pilot/gunner go through a slot located on the front wall of the bulkhead which houses the pilot's instrument panel. Apologies for leading anyone wrong:
Double DOH!
"Made up"?!! That's just wrong on every level!
