Greg Kimsey
Yeah, it's a struggle but I LOVE it.What what again?? Gary S. I think.
Don't fret. Use a glue debonder. Apply with a cotton swab, give it some time, and the dried CA becomes a gummy (I call it snot-like) consistency which you can use the same cotton swab (with the dried debonder) to lightly scrub it off. No harm to the plastic as it is not a cement that chemically fuses the plastic but a glue that lays on top. I know some say I have clean builds but... I am messy and that is my secret. These are two I already used up!Ok, this is drving me nuts. How do I handle this issue?I tried using super thin CA glue and let it seep around the lip but it ended up getting on the top of the trunk body and made a mess I now have to sand and expect the body is ruined. How do you guys handle getting glue on an old seam and not have it let go? HELP!
Sanding stick and water!Thanks Saul, I don't know why I didn't think of that. It worked to get the CA off well enough.
Now to figure out what to do about new plastic cement making old cement release.
tlarmodels.com
Well, as I stated, cement is a chemical reaction so, you can't stop it from weakening a prior bond. In these cases, I switch to a glue (CA, Gator's Grip, et cetera). If the glue completely covers the previous chemical bond and has cured, you can start again with cement.Now to figure out what to do about new plastic cement making old cement release.
Sealing the cement with another glue should have occurred to me, but,..well, it didn't. I guess that was what I was attempting with the superglue, as I knew the cement would not affect the CA so the old part would stay put. This has been an issue for me for several models but never thought to ask about it. No video I have watched where the modeler adds parts later using cement mentions this and I KNOW it had to happen. I guess I was supposed to be smart enough or experienced enough I know. Been building models for 51 years now...and have always just fought the problem.Worst case scenario, knowing that the cement will weaken a prior cement bond, is to use a very thin applicator, others pointed to what they use, to place the cement precisely and blow to evaporate it before the chemical reaction has time to go deep enough to weaken a prior bond.
I learned this from a time I used MEK to build quickly and had a "Tough-n-Flow" as the applicator with (my previously used) insulin 30 gauge syringe to refill it. I see that they now sell it in various ways, including a 'system.'
