centaur567
I want to convert this Nashorn kit by Bandai to a Hummel. What I need to do this are some scale drawings of the gun and it's mounts. So if anyone has some it would be greatly appreciated. Gary S.
Better call Saul...
I gotta get a emoticon from that.
I got you! Keep in mind the shells and shell holders too.I want to convert this Nashorn kit by Bandai to a Hummel. What I need to do this are some scale drawings of the gun and it's mounts. So if anyone has some it would be greatly appreciated. Gary S.
It is...Yeah, I believe the Hummel has the 15cm howitzer. (which is huge)
@centaur567 was able to make the Maverick II bird, this is not as hard once he has the carriage (barrel is easy)...Unless you actually have the 15cm s FH18 gun to go with it, you are going to be fighting a steep up hill battle.
THANKS. Is that from the breech block to the end of tip of the barrel? And what is the measurement of the narrow part of the barrel and the thicker part? Gary S.Barrel length of the 150mm gun with 29.5 Calibers is (29.5x150mm=4425mmm) 92mm (3.63") in 48th scale. I can try to scale the breech block plans I have but I need to gather the books.
Full barrel, I will get my books and see if I can scan the plans I trust, scale them down for you and send privately (since they may be enlarged/reduces when posted here.THANKS. Is that from the breech block to the end of tip of the barrel? And what is the measurement of the narrow part of the barrel and the thicker part? Gary S.
