Home maintenance
moon puppy
Administrator
Staff member
Totally off topic but I'm going there.
The problem? Air conditioner condensation. The solution, French Drain.
This isn't my first rodeo with a french drain. I did it at the old house years ago, air condition condensation was pooling up at the corner of the house against the foundation so I extended the pipe out into the yard and down about a foot.
And of last word it's still working just fine.
At the Happy Acre we had the same problem. The water build up was too close to the house. So I' ran a pipe down the side of the carport out to the yard and dug a hole.
Filled it with gravel
Layer of sand, landscape paper and supervisor approved pavers covering things up.
That was in 22, 4 years later I've noticed the drain is not draining, figured the pipe is clogged up but it always bothered me I didn't run that pipe out over the gravel and only empty into the hole. It started backing up late last year. Well, today was the day to fix things.
I present to you the Trident of Condensation Distribution
I drilled holes in the bottom of the three arms. No that's not the condensatoin already built up. that's the water from where I flushed out the drain pipe.
Added another layer of stones
Under constant supervision
And cover up the works with the pavers.
This should be easy maintenance in the future as well, just lift the pavers and check on things.
Anyway, I don't have any other social media and I was a bit tickled how this turned out. time will tell, just need things to dry out and see if it works.
Years ago my parents finally put in a central air unit. The line ran out the north side of the house, and my dad got tired of the muddy spot. He dug a hole and put liner in it to put a 5 gallon bucket in it. Then every couple of days or so would empty the bucket on stuff he wanted watered. Did that for years. My mom sold the house in 2012 so have no clue what the new owner did with that.
That would be just short of a french drain, he could have put rock and sand in the bucket with some holes in the bottom and never had to empty it.
I lifted one of the pavers this afternoon, it's hot and steamy but around the AC it's dried out and the rocks were wet.
:bigrin:
:bigrin:
He did this 30+ years ago. Woulda, coulda, shoulda. My dad had a lot of mechanical aptitude, but there were a lot of times that he just did NOT think things through. The drawer units on the desk I have (that he made) had the cheapest cheesiest tracks for the drawers that I have replaced 4 sets of the tracks. There are two more sets that I just have not bothered with yet. There is enough misalignment in the cabinet that it will be a hassle and I have had other things to deal with that I would rather do.
