Good, you can figure out the center drill jig.Paddy, you could make one with your skills, no need to buy one. I got my jig yesterday, or was that Friday? I'll be putting this it use soon enough.
I don't think we want to know about your "bare" parts.Isn't it true though that one single part doesn't bare (or bear) the weight of the entire build?
Makes you wonder if the guy making the kits actually builds them to see if they will fit and hold up under their own weight.
I'm a bit confused on how the concentric drill jig is supposed to work. I'll get some photos and show you what I mean. There's some really nice guides for consistent cutting and standing.
First, let me finally blame others, like @jknaus, @Heavens Eagle, @Steve Ski, and @moon puppy for ordering this DSPIAE AT-AP contraption. It is nice and I paid it off with Amazon points received after paying off $3000+ on my credit card (son's PC furniture, and what-not).Good, you can figure out the center drill jig.
The thing is Paddy is that most small carbide drills that are readily available are set with 1/8 inch or 3.175 mm diameter. These are the bits that are used by the PC board fabricating industry for drilling circuit boards. My guess is that it was a standard set up a long time ago and is just set. It works, and everyone uses it.As an observer looking in i would say why 1/8" shafts ? presumably they want you to buy their drills and 1/8" allows for a 3mm drill but realistically you are not going to drill a 3mm hole with a pin chuck. they supply drills down to 0.3mm but these are very tight twist drills ( more twist per inch) which tend to clog easier and being sub 1mm i would want a wide open slack twist for strength and anti clog. In fairness its not going to be a huge problem with a manual pin vice . The plus side is the drills are very cheap, a box of 10 for what i would expect to pay for 2 high quality drills.
The bottom line is with all tools you get what you pay for and in most cases for the average joe thats absolutely fine. I just looked back at the price list for Karnasch milling cutters which we used to use at work and a 2mm carbide end mill is £50. or you can buy 1 for £0.70 from Temu..., so temu are 7042.857142857143% ( i used a calculator for that) cheaper. I wonder why
For this "Assistance Platform" (the AP in AT-AP) carbide and tungsten bits can be used but they can't have a collar as it prevents the body from reaching the work area to cut into stock. I will post a mini-video showing this.The thing is Paddy is that most small carbide drills that are readily available are set with 1/8 inch or 3.175 mm diameter.
I'll try that. I did find that the bits without collars have the size etched on the shank.Saúl, I have found that the plastic collar can be pressed off. It isn't that hard. It's just that it is a size label and makes it easier if it is there.
I bought this very cheap 3 jaw chuck (originally for my General engraver pen) and tried to put it on my Wowstick, it didn't fit. As for with the General engraver, it spun like a Latina at a quinceañera shaking her thang! I guess I will try it on the new toys since the brass collets stop at 3,2mm...i bought a very cheap 3 jaw chuck for my arrowmax and it runs pretty true. Problem solved.
