Airfix Typhoon
moon puppy
Administrator
Staff member
I got a ruling today during the call from Paul. He allowed a WIP in. I picked up this Typhoon play set from Airfix with intent of using some of the vehicles displayed with the Comets but they just don't work. I mean a Tilly in 1934?
I really don't remember starting this kit, don't know why I stopped.
Building in 1:72 certainly has it's advantages.
Small scale with minimal detail rivet counting makes for fast builds. My Puma is getting paint today. All primered and little parts placed. I did cut the slots on the jerry cans tops so there are the three handles. Dug out the BIG Puma and clipped out one of it's jerry cans and assembled it for reference. Oh! My!
Yikes! I'm even doing the bomb loadout. Rich I only hope mine turns out half as good as yours. :pilot
I have RAF Dark Green, Dark Earth, Middlestone (WTF that is) Sky and some others. I do not have the two different shades of grey that this calls for. Really?
The modelling gods have determined that you have insufficient good karma in your account after getting an in progress kit admitted to the campaign.
You will have to sacrifice a chicken and run around the perimeter of your property three times, naked, to replenish your credits.
RichB
No sky on a Typhoon Bob unless its got a tail band ?
Top, Ocean grey and Dark green.... underside medium sea grey.
A Typhoon with 60lb rocket loadout was probably the most lethal aircraft of WWII, we have one here under long term restoration to fly :) just probably not in my lifetime.
I'll make my apologies to RAF purist now. I'm using Vallejo Sky Grey and Neutral Grey for the two missing colors.
Hard demark on the camo colors will come from cutting out the paint guide from the instructions...if that image is to scale.
Not to rain on your parade, if you are doing the 247 Sqn scheme it was a Rocphoon squadron and 439 Sqn was a Bombpoon squadron. Although the Typhoon was designed to be able to switch between bombs and rockets as required the change over put extra workload on the groundcrew. As dive bombing and rocket firing were more art than science better results were achieved by letting the pilots specialize in one role. It also simplified logistics only delivering one type of store to the squadron.
RichB
Truer words have not been spoken. I'm bowing out on this build and MMM this year.
I did not know water attacks Testers lacquer gloss seal coat and strips down to the primer. :bash: :blink
I'm going back to finishing the Carolina Lee scene.
Nah. Testors lacquer stuff is impervious to water, if applied evenly.
It's you that always says "I don't care what subject it is. It a MODEL!"
I encourage you to continue! :good:
Thank you for that, but there will be no typhoon from me. At least not right now.
Here's what happened. I used the Mission Models paint but I short cut it, like I have a couple of times and didn't add the poly sealant. When I sprayed the Testers I can only think that the solvent actually pulled up the MMP pigments to the top, didn't really seal it. And when I started adding decals the green color just washed away. Now that was a neat looking effect and it stumped me at the time but thinking about it this afternoon, that had to be the cause.
