Tim if you have any kind of a drafting or simple CAD program, you can do print outs of the patterns, then get some 3M double sticky sided photo adhesive tape and attach it to the back. The photo adhesive tape is about as sticky as post it notes or a bit less. Then place it on glass and with a sharp #11 blade cut it out. They end up a bit thick, but work quite well unless you spray thick and wet.
Very useful info as I feel like I'll be doing more painted markings in the future.
Making the fuel barrel brackets. Thanks goes to James for posting up what they looked like. Very simple steel rod design welded to the hull. These weren't factory and I'm assuming added in the field. Making two to match out of brass rod isn't as easy as it may look!
Don't forget to get that seam line fixed on the barrel before final paint. Getting dinged for that after all the great work you have done would be sad Tim.
I haven't even begun on the barrel, really. Got it from Classy Hobbies, it came with ridges on the barrel that I don't see on any period photos? So, I'm sanding them off as well as sanding down the pressed stamped lettering to make it more stamped looking.
